interface for a LPT port using MSP430G2 LaunchPad
cakarertugrul
Joined Jan 27, 2021
6
Hi, I have term homework but I have a little help, I have no idea about how to do it? Can someone explain to me, how can I design this project? I investigated the family guide of MSP430G2 but there is no explanation about the LPT. Many thanks.
Write down an interface for a LPT port using MSP430G2 LaunchPad. The hardware interface for the LPT interface is based on D-Sub 25 pin connector. Data will be sent by using Centronics mode at a data rate of 120 kBps.
Useful links:
Detailed information about LPT interface can be found in these links
https://hw-server.com/parallel-port-lpt-ieee-1284#signaly
http://wearcam.org/seatsale/programs/www.beyondlogic.org/spp/parallel.htm
35,059
Since this is homework assignment you have to do the work yourself.
Begin by getting a large sheet of paper and a pencil.
Write down and draw out what you have learned about DB-25 Centronics connection as follows:
Write out pin-1 to pin-25.
Write out the function of each pin.
Write out the signal direction of each pin.
Draw a block diagram of a Centronics mode device with 25 connections to a MSP430G2 LaunchPad.
Draw a flow chart of what is supposed to happen between a Centronics mode device and the MCU with reference to the function of each pin.
cakarertugrul
Joined Jan 27, 2021
6
I just wanted to consult. Of course, I should do the work. I didn't mean anything else. Thank you for your help. I appreciated.
