Hey guys so I need a little help with this question : if I disconnect a lcd from a device can i connect a different lcd screen to the same device ? I dont know much about lcds and google wont help this time but any answer is appreciated
There are two levels of concern.Hey guys so I need a little help with this question : if I disconnect a lcd from a device can i connect a different lcd screen to the same device ? I dont know much about lcds and google wont help this time but any answer is appreciated
I dont know but now ik that they have to match so that part is all good but lets say u have a lcd with the same connections but different size screen will the lcd still function like it would if it had its orginal size?The interface and command set have to be compatible, what is the part/type No?
I got the first part but the second part i have no idea what ur talking about remember i dont know muchThere are two levels of concern.
1) make sure the same, or similar, LCD driver chip is on the display. Usually a surface-mount chip can be seen on the back of the display.
2) make sure the communication pins from your cable to the input pins on the display chip (LCD driver) chip are arranged in the same order by whoever designed/built the display.
I know that i just wanted to know is there like a universal connector of some sort ?Hi,
SEE at the back of LCD and you will find listing of serial number,part number ,manufacturer, and date and made from.
Usually just enter in the google the part number or manufacturer, it will link you to this data of such Lcd.
Connecting such Lcd of different pin assignment in the connector it will not go in. So review your LCD unit characteristic and parameters.
I have no ideaWhat type or kind of LCD is this? Got a picture to post?
Too many possible variables to know without part No.s.I dont know but now ik that they have to match so that part is all good but lets say u have a lcd with the same connections but different size screen will the lcd still function like it would if it had its orginal size?
Yes.I dont know but now ik that they have to match so that part is all good but lets say u have a lcd with the same connections but different size screen will the lcd still function like it would if it had its orginal size?
There are several "universal connectors". Which makes them not universal, of course.I know that i just wanted to know is there like a universal connector of some sort ?
Its not mine its my fathers he gave it to me because he broke it somehow which is why i am here and telling you guys that i dont know what it is bc when i got it the lcd was beyond repair and the device itself was in pretty bad shapeYou should be able to tell us that.
Alright thanks for the infoThere are several "universal connectors". Which makes them not universal, of course.
What you are looking for is called: communication standards.
Just of the top of my head:
4 bit parallel
8 bit parallel
IIC (I2C)
4 bit and 8 bit parallel are compatible.
IIC is one of the serial standards. There are several others.
hey so i did some research and I found out that the lcd is of a acer iconia 10 i hope this helps a littleThe interface and command set have to be compatible, what is the part/type No?
| L | Are mouse switches interchangable | General Electronics Chat | 2 | |
| C | Design of two interchangable power sources | Power Electronics | 11 |
