Interchangable lcd?
Killerbee65
Joined May 15, 2017
256
Hey guys so I need a little help with this question : if I disconnect a lcd from a device can i connect a different lcd screen to the same device ? I dont know much about lcds and google wont help this time but any answer is appreciated
GopherT
Joined Nov 23, 2012
8,009
There are two levels of concern.
1) make sure the same, or similar, LCD driver chip is on the display. Usually a surface-mount chip can be seen on the back of the display.
2) make sure the communication pins from your cable to the input pins on the display chip (LCD driver) chip are arranged in the same order by whoever designed/built the display.
JUNELER
Joined Jul 13, 2015
183
SEE at the back of LCD and you will find listing of serial number,part number ,manufacturer, and date and made from.
Usually just enter in the google the part number or manufacturer, it will link you to this data of such Lcd.
Connecting such Lcd of different pin assignment in the connector it will not go in. So review your LCD unit characteristic and parameters.
Killerbee65
Joined May 15, 2017
256
The interface and command set have to be compatible, what is the part/type No?
Max.
I dont know but now ik that they have to match so that part is all good but lets say u have a lcd with the same connections but different size screen will the lcd still function like it would if it had its orginal size?
Killerbee65
Joined May 15, 2017
256
I got the first part but the second part i have no idea what ur talking about remember i dont know much
Killerbee65
Joined May 15, 2017
256
I know that i just wanted to know is there like a universal connector of some sort ?
MaxHeadRoom
Joined Jul 18, 2013
30,661
Too many possible variables to know without part No.s.
Max.
shteii01
Joined Feb 19, 2010
4,644
There are several "universal connectors". Which makes them not universal, of course.
What you are looking for is called: communication standards.
Just of the top of my head:
4 bit parallel
8 bit parallel
IIC (I2C)
4 bit and 8 bit parallel are compatible.
IIC is one of the serial standards. There are several others.
Killerbee65
Joined May 15, 2017
256
You should be able to tell us that.
Its not mine its my fathers he gave it to me because he broke it somehow which is why i am here and telling you guys that i dont know what it is bc when i got it the lcd was beyond repair and the device itself was in pretty bad shape
Killerbee65
Joined May 15, 2017
256
4 bit parallel
8 bit parallel
IIC (I2C)
Alright thanks for the info
