Int1 strange problem with PIC18f87k22
Picbuster
Joined Dec 2, 2013
1,062
Problem int0 and int2 are working but int1 is not.
Why is INT1 not working?
Picbuster
Part of interrupt routine
void interrupt ISR()
if (INTCON3bits.INT2IF) // working
INTCON3bits.INT2IF=0 ;
Xport1('&');
Display_Bl = Off; //led
if (INTCON3bits.INT1IF)
INTCON3bits.INT1IF=0; // not working
Xport1('#');
Display_Bl = On; // led
//================ end of interrupt
// ========== in main setup for interrupts
TRISB = 0b00001111; set inputs
INTCON3bits.INT1E=On;
INTCON3bits.INT1IE=On; // enable interrupt 1
INTCON3bits.INT2E=On;
INTCON3bits.INT2IE=On; // enable interrupt 2
INTCON3bits.INT1IF=0; // clear flag
INTCON3bits.INT2IF=0; // clear flag
INTCONbits.GIE=On; // global on
INTCONbits.PEIE=On;
while (1) //loop
__delay_ms(20); // just wait
//========================= test input b1 =========================
Find out if connection to chip or chip itself fails
INTCON3bits.INT1IE=Off;
disable interrupts for int1
while (1)
if (PORTBbits.RB1) // input RB1 is Working !!!
Xport1('@');
// hardware input and chip are working but INT1 when activated is remains dead.
Picbuster
Joined Dec 2, 2013
1,062
as in it seems to be stuck in a constant interrupt loop or the interrupt just doesn't reset and the rest of the program works as expected.
Thank you for the reply.
Constant interrupt loop should stop all interrupts but they remain working.
(Int2 int0 timers etc).
However I will look into this you never know.
Picbuster
geekoftheweek
Joined Oct 6, 2013
1,429
Picbuster
I thought that is what you meant, but wanted to be clear as I have enabled the wrong interrupts before and essentially put the program in a constant interrupted state due to not clearing the active interrupt.
Are you sure the interrupt pin is changing states? As a normal I/O pin it is defined as TTL with a low level of < .8 V while when configured as an interrupt it is a Schmidt Trigger input with a low level of <.2 V.
In other words PORTBbits.RB1 would switch to 0 at less than .8 V while the INT1 would not switch to 0 until less than .2 V.
Maybe switch the interrupt edge in your program while in the interrupt routine and see if it fires again when you switch to a low level?
That is what I would suspect short of failed interrupt logic in the PIC as everything else looks right so far.
Edit:
Just to clarify what I propose:
Code:
void interrupt ISR() {
     if (INTCON3bits.INT2IF)  { // working
          Xport1('&');
     if (INTCON3bits.INT1IF)  {
//--------------------------------------------------   test section
          if (INTCON2bits.INTEDG1) {  // check if triggered on low to high or high to low
               Xport1('#');  // low to high trigger
          else {
                Xport1('$');  // high to low trigger
          INTCON2bits.INTEDG1 = ~INTCON2bits.INTEDG1;  // modify trigger  -- my apologies if this could be written better as I normally use ASM
//--------------------------------------------------   end of test section
