Instrumental Amplifier Spice Simulation
Alec_t
Joined Sep 17, 2013
15,156
If you're running LTspiceXVII on Windows10 then the .sub file and the .asy file need to be in the ....\User\Documents\LTspiceXVII\lib\ path if you want the model to appear in the LTspice drop-down list. Otherwise you can save them in the folder where your .asc file is.
ericgibbs
Joined Jan 29, 2010
21,557
hi,
I used two Voltage sources to give a differential input signal to the INA.
The signal is set as a Piece Wise input.
ie;
PWL
at 0 sec the signal level is 0V
at 1 sec the signal level is 0.5v
As the polarity of the two sources have a 180 degrees phase difference, it means the differential signal Vsig is 0v thru 1v over a 1 second period.
Is this what you are asking.?
E
EDIT:
This image shows the va, vb and the differential va_vb , input signals
