Instrumental Amplifier Spice Simulation
ayractgc
Joined Feb 3, 2018
52
Can anyone help me to write spice code to simulate instrumental amplifier INA128?
I have INA128 subcircuit code but ı don't know how ı can write it.
ericgibbs
Joined Jan 29, 2010
21,551
hi ayrat,
Unzip this file, it has the IN128 , sub, asy and a test asc file.
Keep them in the same folder,
If you post your asc files we can help.
E
ericgibbs
Joined Jan 29, 2010
21,551
hi,
That Lib is the same Texas Inst model data that I have included as a sub file in the zip I posted for you.??
If you change the internal values it will not be a standard IN128 model.
Have you tried running the asc file I posted.?
E
EDIT:
The IN128 is designed for dual supply operation.
50K for the external Rg will be a Gain of 2
Please explain what you want to do for the IN128 project.
ayractgc
Joined Feb 3, 2018
52
hi,
E
EDIT:
How can ı run asc file in Pspice ?
it allows for cir files simulation :S i didn't understand sorry.
I want to give 1V input and ı want to see 10V as output voltage so I choose Rg 5k to have 10 gain
ericgibbs
Joined Jan 29, 2010
21,551
hi,
The symbol in LTSpice is the 'asy' file in that zip.
I do not use PSpice, but other members may help you with that problem.
E
Alec_t
Joined Sep 17, 2013
15,152
Hi avractgc,
As Eric said, post your .asc file and tell us exactly what error is reported. You need to help us to help you, or else everyone is wasting their time.
ayractgc
Joined Feb 3, 2018
52
Hi avractgc,
Actually there is no error but library doesnt include ina128 component so i should apply it t the lib files.İ couldnt do it
