Installing a Boot up chime to my N64
ItsHoggle
Joined Jan 27, 2025
I'm trying to surpise my husband gor his birthday with a modded N64. One mod I'm tyring to do is to add a start up chime to the power switch. So that way when he turns it on, it okays a song. I followed a YouTube video and wired it exactly as the person does in the video. He was able to make it work, I can not. In fact as seen in the photos I attach I can only make it work when I touch the wires leading from K1 to Grd. It does not work when I have then soldered in. I'm a novice at this, and I can't figure out what I did wrong. Mine is wried as the youtuber wired his, but mine does not work. Any insight would be greatly appreciated.
ericgibbs
Joined Jan 29, 2010
21,628
Hi Its,
It is most likely the K inputs are Low going Edge triggered, which means they have to be momentarily connected to 0V/Gnd.
That's why it works when you just touch the K wire Onto 0V
A permanent soldered joint will not work.
E
ItsHoggle
Joined Jan 27, 2025
Hi Its,
E
Do you have any idea of how I can wire it so that it's triggered when I turn the 64 on?
ericgibbs
Joined Jan 29, 2010
21,628
hi its,
A local electronic repair man would be able to fit that circuit for a small cost.
It's a bit too far for me to make a house call. :)
E
