Install Wireless Remote on Pallet Stacker ?
wirenutz
Joined May 18, 2024
21
(semi electric) 12vdc Apollo Pallet Stacker. i would like to install a wireless controller up/down ( range 20 to 30 feet) on a pallet stacker & please be specific. like something on amazon website. it will need to actuate a solenoid or maybe a relay(contact hold). since the up/down (on the stacker) has to be manually held to raise & lower, i will need a controller that will hold contact until a limit switch (at a designated stop point) activates & opens circuit. if i have to hold the button down (on the remote) for the duration of lift (stop point) batteries will not last long. thx
wirenutz
Joined May 18, 2024
21
I'm going to venture a guess that people are going to be reluctant to suggest any parts to modify a safety circuit to a device they have no idea what it is being used for. OSHA would have a field day if this is for a business and something went wrong.
i am a 1 man operation in my shop. i store material in the loft of my shop. this gives me more floor space. i mounted this lift stationary to replace my rope & pully. standing at the lift holding the handle while lifting a load is a waste of time. would be nice to lift the load while i am also busy working..... suggest ; i would not recommend doing this but if its for material only then this 'item' ('model #' 'on amazon') will work. OSHA is more than welcome to inspect this lift, plus, you can buy these lifts with the remote, but they cost a lot more.
28,571
OK, the fatal problem that I see is a fairly powerful device running in an unsupervised manner. My suggestion is a hoist with enough power to move rapidly with a load. Then a pendant with up and down buttons. Much faster than the pallet stacker and a whole lot safer than even an unmodified stacker.
