Install a piezo disc in place of an electrit mic
Allangee
Joined Jul 14, 2022
Hi guys. I need some help modifying an rgb controller I installed in my drumset..It is triggered with sound problem is it picks up surrounding sounds even at lowest sensitivity and lights up the rgb.I want to replace the electrit mic with something like a piezo disc so it is triggered with vibration, lights up the rgb tape each time a drumset is hit..Any suggestions?
ThePanMan
Joined Mar 13, 2020
953
Welcome to AAC.
Can you provide a schematic? Knowing whether it can be done or not - or if so - how - depends on the electronic package. At worst, a picture may prove of some use, but to just guess isn't our favorite way of modifying electronics.
28,490
The piezo disc will provide volts instead of millivolts, and so some experimenting with attenuation will be needed. The piezo function is more efficient than the electret.
