Inside a GSM antenna
Martino Chiro
Joined May 1, 2015
128
Now you can clearly see that the GSM antenna is connected directly to the coax.
The GPS coax goes to the box.
Yes, my question is:
the capacitance i measure at the end of the GSM coaxial cable (2,5m long) is the capacitance of the cable itself or also the one of the PCB traces ?
I measure around 400 500 pF with a multimeter in the 400nF range (not a true capacitor, i know).
Martino Chiro
Joined May 1, 2015
128
Sorry for the delay.
I measured the cable alone (2,5m of RG174): 266pF
the PCB alone: more or less 2pF
I measured also a 4m cable of RG174 (the antenna is available in two versions: with 2,5 and 4m of cable): 402pF
The GPS module is not easy to open.
Anyway, the measure of capacitance is out of range.
Thank you for your help.
