Digital. I mean I think it's correct. How can I testAre you using an analogue or digital meter to read the voltage? Have you got the feedback correctly phased? maybe the thing is one huge oscillator if you've wired it with positive feedback which could give very strange readings on the anodes (plates)
Yes, indeed! Apart from the tube's maximum Eplate specification (800V), Capacitor 'A''s MWV rating of 500V argues your point most effectivelychecked plate votlage and its at 950 on en el34... that cannot be good.
Well... Clearly so large an over-voltage condition cannot owe merely to under-loading -- ergo the power supply transformer is either defective ('non circular' short in primary) or misapplied...what could be wrong?
Merely remove the finals and measure the EMF at tap 'A'Digital. I mean I think it's correct. How can I test
I think I found it. If you look at the switch in the amp some genius took a wire that connects to the bottom left pin of the power switch and connected it to 3 pins on that switch. That surely would argue missapplied rather than shortedRemove the finals and measure the EMF at tap 'A'
Best regards
HP
Either way I see only a single, untapped primary winding?I think I found it. If you look at the switch in the amp some genius took a wire that connects to the bottom left pin of the power switch and connected it to 3 pins on that switch. That surely would argue missapplied rather than shorted
Well I was getting 450 on the plate before someone messed with those wires so.Either way I see only a single, untapped primary winding?
Best regards
HP
Good deal! A simple problem is the best sort!Well I was getting 450 on the plate before someone messed with those wires so.
@recklessrog Please be advised that the OP identified the problem several posts back...Also, double, (even treble) check that you have connected the output transformer primary taps to screen grads correctly and that the Anodes (plates) are connected as per the original. even if you have got the secondary correctly wired, with the feedback point the same as original, by reversing the primary connections, would cause positive feedback and make it oscillate, probably at a frequency above audible range.
Oh yes thanks, for some reason the posts had not updated until just now and I had not seen the other replies. Probably my slow internet here. All good as long as he's got it fixed now@recklessrog Please be advised that the OP identified the problem several posts back...
Best regards
HP![]()
With my hearing at my age, i doubt I would hear it ha ha. But like I said earlier, if you remove the valves (tubes) and the voltage is correct, then It is a fair indication that it's oscillating when they are in.Oscillation can cause that issue. However you'd also hear a squeal. I'm going to wire the switch properly and try that. If not I'll swap wires.
Oscillation was a possible cause of the excessive voltage readings PRIOR to discovery of the real problem! - There is no longer any reason to suspect oscillation even in the event the amp fails to function!Oscillation can cause that issue. However you'd also hear a squeal. I'm going to wire the switch properly and try that. If not I'll swap wires.
Yessir. First I need to get some sound out of her. Then comes new caps.Oscillation was a possible cause of the excessive voltage readings PRIOR to discovery of the real problem! - There is no longer any reason to suspect oscillation even in the event the amp fails to function!
Also - Inasmuch as the over-voltage condition will have significantly abused the filter capacitors, 'preemptive' replacement of same is advisable...
Best regards
HP![]()
Sounds like a plan!Yessir. First I need to get some sound out of her. Then comes new caps.
Not true in some amplifiers. Certain Fender amps are famous for cutting out (going silent) during play and the reason is that they are hard slammed in ultrasonic oscillation. One look at your schematic and I thought, "Fender Deluxe Reverb...without the reverb section". That's why an amp repairman is sure to fail on those problems if he doesn't own an oscilloscope.Oscillation can cause that issue. However you'd also hear a squeal.
Aye! I've known 'HIWATT' Amps to 'take off' in the low HF region (i.e. fundamental at 4MHz - 6MHz)Not true in some amplifiers. Certain Fender amps are famous for cutting out (going silent) during play and the reason is that they are hard slammed in ultrasonic oscillation. One look at your schematic and I thought, "Fender Deluxe Reverb...without the reverb section". That's why an amp repairman is sure to fail on those problems if he doesn't own an oscilloscope.
