Hi, I have a high power boost dc-dc converter that is attached below. I supply him through a rechargeable 9Volt battery. In specific, between the battery and the converter I have placed another dc-dc convertet to keep the battery level stable at 11Volts. So, the input of the high power dc-dc converter is the 11Volt output of the smaller boost dc-dc converter. The output of the hig power dc-dc converter is about 65Volts. The output load of the high power dc-dc converter is about 11k ohm. I have noticed that when I turn on the switch there is a big input inrush current. I would like to ask the followings. Firstly, how can I measure that input inrush current? Secondly, how can I limit that current? I have read about NTC thermistors, but which one should I pick and where should I place it in the circuit? Thank you.
https://gr.banggood.com/Geekcreit-4...ntry=GR&a=1689064389.7381&akmClientCountry=GR
