Here is a schematic of what iam trying to do.The Voltage sources are output pins on the IC and only one output pin will be pulled high at once.I believe the led will light up but will the IC have any damage or problems from connecting the 3 output pins together to the one led?or anything else to worry about?thanks
http://tinyurl.com/ybr5egrr
Mod edit: added local image from online schematic generator
