hi, i'm a dumb newbie!
I need to find a suitable transceiver for transmitting a voltage signal (0-5 Volts) from a sensor. From the sensor's datasheet I read the following: "Please note connection considerations: Analogue output load is min. 10 kOhm, max. 20 nF."
This means that the sensor has to be connected to a device (load) with an input impedance of at least 10 kOhm, right? But why is the maximum value given in farads?
Thanks
Thanks
