Hi all,
I'm having a weird issue here - I have 2off 24V power supplies each bridged together in a load-share configuration using diodes to supply an SBC. The SBC can run off a wide range input from 9V to 36V.
I find, however, that when I use the inline diodes on the power supply, the SBC doesn't power up and I can't figure out why. I thought there might be a voltage drop across the diode but this should be well within the acceptable range, so my only other guess is that there's a resistance in the diode which is limiting the current? Is this a known problem? Simple diagram attached.
The diodes are there to allow for some redundancy - if one supply gets a short-circuit over the output then the other will still be able to function.
