What is the tiniest 240VAC to 12VDC (2.5AMP) inline converter out thee?
2Pringles
Joined Apr 9, 2022
38
dendad
Joined Feb 20, 2016
4,636
What is the reason you need a "tiny" power supply?
I would advise you to stay away from tiny power supplies like you show above. For one thing, I doubt an LED driver is the sort of supply you need, and the electrical insulation in most of those cheap power supplies leaves a lot to be desired. Some are quite dangerous.
Those from Farnell you could trust.
But, all that you show (the first would not open, due to site maintenance) are way too small in power for what you asked for.
Don't confuse "3W" with "3A".
12Volts * 2.5Amps = 30Watts.
For reliability, do not skimp on your power supply. Maybe look for a 40W or 50W version.
panic mode
Joined Oct 10, 2011
4,953
maybe consider another router. for those who like to travel lite, there are nano routers which are tiny and consume much less power.
2Pringles
Joined Apr 9, 2022
38
Need small for a compact project I am working on.
Good idea, but still needs ac to dc conversion
Yes it is.
More power requires more volume.
That's the physics.
Understood, however, I am wondering are there multiple ways to skin a cat, and do some of the other ways of converting AC to DC use less material(but could be more expensive for example?)
dendad
Joined Feb 20, 2016
4,636
It seems very small - It can output up 3A at 5V and 2A at 12V.
That is just a step down reg from maybe a 19V laptop supply to the required 5 or 12V. Not mains input.
As it sound like your device will be plugged in, why cannot you use a plug pack?
