Initial rate of growth of the current
Antony 16171
Joined Apr 7, 2021
11
Hello , i was asked to find ''the Initial rate of growth of the current'' but am not quiet sure how do i do that ,
Full questions:
A coil having a resistance of 33ohms and an inductance of 3.3H is connected across a 100v dc supply.
So i used Ltspice to find it ,but am not sure what measurement i need to take .
Edit:i came up with (e/33)*(1-e^(-2/(3.3/33))) = 0.0823721764501894 , is that right ?Capture.PNG
wayneh
Joined Sep 9, 2010
18,184
Ditch the simulator and recall your math. dI/dt at t=0 = ?
Maybe you've got it but I can't check your work if you don't show it.
This is homework, right?
Antony 16171
Joined Apr 7, 2021
11
Full questions:
Edit:i came up with (e/33)*(1-e^(-2/(3.3/33))) = 0.0823721764501894 , is that right ?View attachment 235257
ive done 2 equations but not sure if 1st one or 2nd one is right or none of them at all , i did.
and
L/V=3.3H/100V=0.033 s/a
wayneh
Joined Sep 9, 2010
18,184
Vr = I • R ohm's law
Vi = L • dI/dt definition of an inductor
Vt - Vr - Vi = 0 Kirchoff's law
Vt - I•R = L•dI/dt algebra
dI/dt = (Vt - I•R)/L = V/L at t=0 when I=0
dI/dt = 100/3.3 = 33A/s^2
C'mon guys, you know this stuff and it's not that hard.
Papabravo
Joined Feb 24, 2006
22,116
You cans also ask LTspice to plot the derivative of current i, with respect to t. That will give you an initial value which will decay toward zero.
Antony 16171
Joined Apr 7, 2021
11
