Hi. I was going to add a very simple push pull circuit to a semi-commercial product. After a second thought... maybe this is not as simple as adding two transistors - as this is typically described in theory articles. This needs to be robust enough to be added to... well, kind of commercial product.
24V push-pull outputs are "everywhere" so maybe there is a cheap chip for this. All I found include opto-coupler - which makes sense since that is probably often the requirement in such applications.
A
A
