Inductors and op-amps ?
DarthVolta
Joined Jan 27, 2015
521
I know the basics of inductors and op-amps, why are inductors so rarely used in op-amp circuits ? I can't really remember any circuit besides an LC tank oscillator's, that use them ?? Even in "compensation" circuit's I've worked on, they'll have an RC network, but no inductor's.
danadak
Joined Mar 10, 2018
4,057
Because with OpAmps and C's we can create a circuit, filter for example, whose response
looks like it has L's in it. Inductors are bulky, costly compared to R & C.
Regards, Dana.
27,717
Another reason why inductors are not used is that at the lower frequencies, especially audio frequencies, inductors are physically large, much bigger than the resistors and capacitors. Besides that, they cost more. So in addition to the reasons given in post #2, which are certainly correct, we have these 2 additional reasons. And then one more problem with many forms of inductors is that they will pick up noise from any magnetic field that has lines of magnetic flux passing through the inductor. So there are the reasons why they are not used as much.
DickCappels
Joined Aug 21, 2008
10,661
Inductors are lossy and bulky while capacitors can be high Q and compact, and much less expensive.
One engineer I knew refused to use inductors even in video filter applications (in the mid-1980's when op amps did not yet work at video frequencies) because he was afraid of magnetically induced interference being picked up by them.
38,572
There is an opamp circuit configuration called a Gyrator, that emulates an inductor using resistors and capacitors.
It's sometimes used to create audio notch and other types of low-frequency filters.
AnalogKid
Joined Aug 1, 2013
12,174
Of the three basic passive electronic components, inductors are the hardest to produce in high volume with tight accuracy.
Also, they do not hold to true inductive characteristics over a wide frequency range. In other words, a real-world inductor is a lot farther away from a theoretically perfect inductor than real-world capacitors and resistors are from their theoretically perfect counterparts.
Also they are relatively large, heavy, and expensive.
For all of these reasons and more, designers have developed circuit techniques that achieve the desired results without using an inductor - even when an inductor is the perfect part for the job. A gyrator circuit is a good example of this.
ak
