Regulators without inductors
engr_david_ee
Joined Mar 10, 2023
364
I was looking at the charge pump regulator CAT3200TDI-GT3 datasheet that used a voltage doubler inside. The efficiency is 80 %.
If I have input 4 V and I need output 5 V with load current 80 mA for example. Does it mean I need more then 80 mA on the input side ?
We can not have higher output voltage and higher output current with low input voltage and low input current, right ?
Ian0
Joined Aug 7, 2020
13,279
Calculate the output power.
Divide by 0.8 to give the input power (because the efficiency is 0.8)
Input current = power divided by input voltage.
Papabravo
Joined Feb 24, 2006
22,111
That is correct. The simple rule is that power out will always be less than power in. Working backwards:
\( 5\text{ V}\times80\text{ mA}\;=\;400\text{ mW, Output power} \)
\( \cfrac{400\text{ mW}}{80\%}\;=\;500\text{ mW, Input power} \)
\( \cfrac{500\text{ mW}}{4\text{ V}}\;=\;125\text{ mA, Minimum input current} \)
