what will be the inductance of a solenoid inductor if these are its parameters:
" 5 turns, 7mm diam, 9mm length " i think it will be 100nH, am i right guys!
I came up with 120 nH using 18-24 gauge wire (the 24 gauge being such as found in Cat 5 cable).what will be the inductance of a solenoid inductor if these are its parameters:
The inside diameter is 7mm. The average diameter to the middle of the wires which make up the coil is 7.9mm.the diameter is 7 mm not 7.9mm,so please check it again
The above was calculated for 18 gauge.what if i use AWG #18 copper wire! what will be he inductance!
