Induction heater by MOSFET IRFN 260
panic mode
Joined Oct 10, 2011
5,261
thanks, very interesting.
actually it also shows center tap variant and confirms startup problems, no regulation etc.
there are the diodes crossed to other transistor drain so if that transistor i on, Vgs of other is limited. may not be perfect if transistor is not fully on.
shortbus
Joined Sep 30, 2009
10,049
That is why what ever is powering these ZVS circuits need to be on and up to voltage before the ZVS is turned on.
shortbus
Joined Sep 30, 2009
10,049
The one I have has the mosfets mounted on the edge of the board, so any size heat sink can be used. A board like that really isn't suited for what your doing. Why not just buy a ready made ZVS? It would be up and running and cost less money in the components you have destroyed so far. If everything isn't the right values, like your homemade inductors, your fighting a losing battle, sorry. The one I have -
https://www.ebay.com/itm/1000W-ZVS-...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
D Ramesh
Joined Oct 6, 2019
13
Dear sir, yesterday night I faced a problem one of MOSFET irfp260n heating with full current .this happened when was shifting to abigger heatsink evven both MOSFET are seperated by sheild .doubt is weather MOSFET would have fail . Sir .
shortbus
Joined Sep 30, 2009
10,049
It seems like you think that a bigger heat sink will cure a bad choice of components. ALL of the components must be designed and the ones used in the drawn schematic. You can't espcially take an unknown ferrite and wind a few turns of wire around it and consider it correct for the circuit. All parts must be within the values in the circuit.
D Ramesh
Joined Oct 6, 2019
13
Dear sir . Today one event I meet in induction heater while loading a small graphite curcible. 25 percentage inside the tube suddenly the 2gates of MOSFETs started burning from the MOSFET bottom all collapsed can utell the reason sir
Petespaco
Joined Jan 9, 2020
I know this thread has been dormant for a couple of months, but, since folks are still apparently reading it I want to make a couple of comments:
1.-I am the guy who blew up several Mosfets while figuring out how to make the Chinese ZVS induction heaters work reliably.
https://spaco.org/Blacksmithing/ZVSInductionHeater/1000WattZVSInductionHeaterNotes.htm
Near the top of the page you will find the schematic that typifies the Chinese ZVS induction heaters.
This page also links to my other pages about induction heating, including the use of the 1800 watt and 2500 watt units.
2.-The Mosfet listed in the title of this thread concerns me. It is: IRFN 260.
All of the heaters I have use the IRFP260N.
3.-For D Ramesh: If you want to melt gold, you must use a 48 volt power supply.
Think about the output wattage----- 12 volts X 20 amps = 240 watts. 48 volts X 20 amps =960 watts.
Converting watts into BTUs: One watt = 3.4 BTU. So, 240 watts X 3.4 BTU = 816 BTU. And: 960 watts X 3.4 BTU = 3264 BTU.
That's not a lot of energy, especially since some of that power is lost in the circuitry and some is lost to convection and to radiation. A Bernzomatic TS-4000 propane torch puts out about 4000 BTU at best, just for reference.
As others have said, I suggest simply purchasing one of the available devices. I also think you will need the 2500 watt model for the work you intend to do.
Here's one link to a 2500 watt Kit:
https://www.aliexpress.com/item/400...chweb0_0,searchweb201602_1,searchweb201603_53
If you google "ZVS induction heater", you will get dozens of options. As others have said, you can't buy all the parts you need for the price of many of these kits.
shortbus
Joined Sep 30, 2009
10,049
Thank you for doing your experiments! They helped me to choose what to buy. Since then I give a link to your site whenever there is a question about these.
