Inductance of Solenoid with Solid Metal Core With respect to frequency
Stoyan.Nikolov.2Induction
Joined Nov 26, 2023
44
Inductance of Solenoid with Solid Metal Core With respect to frquency
Hi. Consider the Solenoid/Inductor Like one the Picture. There is Air gap between the coil and inserted solid metal.
Hi. Consider the Solenoid/Inductor Like one the Picture. There is Air gap between the coil and inserted solid metal. The solid metal is from Aluminum or Copper (Both have relative magnetic permeability , close to 1 regardless of temperature).
What will happen with inductance of the given Solenoid if we increase the frequency of the applied voltage.
Irving
Joined Jan 30, 2016
5,195
Welcome to AAC.
Is this a homework question? It should be in 'Homework Help' forum.
We need to see your own attempt at an answer before we can assist...
28,113
The inductancwe will not change, but the inductive reactance will increase in proportion to the frequency, because Inductive reactance=Xl=2 (pi) F L
