Indicator lights for push button
seayaker
Joined Jan 27, 2009
55
This is a simplified sketch for an Arduino midi controller, I want to add indicator lights to the buttons so that they turn on/off with the note on/off commands I tried adding pinMode(13, OUTPUT); to the setup, and then digitalWrite(13, HIGH); and digitalWrite(13, LOW); to the loop but the lights still don't work any suggestions?
#include <Bounce.h>
const int channel = 1;
Bounce button0 = Bounce(0, 5);
void setup() {
pinMode(0, INPUT_PULLUP);
void loop() {
button0.update();
if (button0.fallingEdge()) {
usbMIDI.sendNoteOn(60, 99, channel); // 60 = C4
if (button0.risingEdge()) {
usbMIDI.sendNoteOff(60, 0, channel); // 60 = C4
while (usbMIDI.read()) {
seayaker
Joined Jan 27, 2009
55
Only 1 button is connected to pin 0 with the led connected to pin 13, I just need to adjust the code to turn the led on/off with the note on/off
danadak
Joined Mar 10, 2018
4,057
Show the code where you did the writes to the LED pin.
Is the LED polarity correct in circuit ? Circuit looks like -
Drive high to turn on -
Regards, Dana.
seayaker
Joined Jan 27, 2009
55
Regards, Dana.
Regards, Dana.
Regards, Dana.
This is how I was told to do it but it only lights the led when I hold the button down I need it to turn on/off with the note commands. If you press the button while it's off it will turn it on, if you press it while it's on it will turn it off. I'm using a teensy 3.2 which uses 3.3v so no resistor is needed for the led.
#include <Bounce.h>
// the MIDI channel number to send messages
Bounce button1 = Bounce(1, 5);
Bounce button2 = Bounce(2, 5);
void setup() {
pinMode(1, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
void loop() {
button0.update();
button1.update();
button2.update();
if (button1.fallingEdge()) {
usbMIDI.sendNoteOn(61, 99, channel); // 61 = C#4
if (button2.fallingEdge()) {
usbMIDI.sendNoteOn(62, 99, channel); // 62 = D4
usbMIDI.sendNoteOff(60, 0, channel);// 60 = C4
if (button1.risingEdge()) {
usbMIDI.sendNoteOff(61, 0, channel); // 61 = C#4
if (button2.risingEdge()) {
usbMIDI.sendNoteOff(62, 0, channel); // 62 = D4
Regards, Dana.
Regards, Dana.
#include <Bounce.h>
void setup() {
void loop() {
button0.update();
button1.update();
button2.update();
danadak
Joined Mar 10, 2018
4,057
Try a test case where you simply flash the LED,
Code:
int ledPin = 13;                 // LED connected to digital pin 13
void setup()
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
void loop()
  digitalWrite(ledPin, HIGH);   // sets the LED on
  delay(1000);                  // waits for a second
  digitalWrite(ledPin, LOW);    // sets the LED off
Regards, Dana.
Wolframore
Joined Jan 21, 2019
1,748
Did you declare the buttons? You have code all over the place. I’m surprised it compiled.
Add in setup( )
int button0 = 0;
Etc...
