I made a 10 MHz xtal transmitter, it transmits perfectly at 10 Mhz and weaker at the harmonics, it is composed of an oscillator, audio stage and RF out . Thing is it only reaches 2 meters . How can its power be increased, does voltage do it ?
Thanks a lot man , I will .WWV is more than just a time station. For those who do not have a Caesium clock, WWV serves as a fairly accurate reference for aligning things like frequency counters. I zero-beat against WWV all the time to ensure my counter is accurate. Imagine how many things can get screwed up if someone zero-beats to your signal at 10.0021248652 MHz when aligning their equipment.
I don't think you understand how radio propagation works. At 10MHz, your signal will hit the ionosphere and come back down. If you happen to get your antenna right, just a mW or two of power might be heard around the country. The National Institute of Standards and Time, along with the FCC, will be out to get you. Good luck.
Thank you so much.Thanks a lot man , I will .
