Increasing current of a digital signal
Saurabh.30
Joined Apr 27, 2021
6
I am working on a project which require to increase the current of a 5v high speed digital signal from 20ma to 100-150ma. can someone help me how to achieve that
Deleted member 115935
Joined Dec 31, 1969
Easy answer is you need a buffer,
to point you in right direction,
what voltage out , what is the edge speed you need ( bandwidth )
and anything else you can tell us about the load,
Relay, led , laser , resistor or what ?
BobTPH
Joined Jun 5, 2013
11,647
What is the load and what is high speed?
Does it have to sink current or source it or both?
It could be as simple as a BJT or MOSFET used as switch.
Bob
Ian0
Joined Aug 7, 2020
13,278
If you just need more current, but only 5V, then all 4 sections of a 74AC125 would do 100mA and still have the speedy rise/fall times.
A 74AC541 won‘t gain much more, as you reach the supply pin limits.
Saurabh.30
Joined Apr 27, 2021
6
output is from Arduino so it'll have variety of loads
Ian0
Joined Aug 7, 2020
13,278
So you have a variety of answers depending on the load:
for push-pull 3.3V or 5V logic up to 100mA at full speed = paralleled sections of 75AC125
for push-pull up to 18V with 30ns rise-time = MPC1401
for single ended with load connected to a higher voltage = single MOSFET - choose MOSFET Vds/Id to suit load
for single ended with load connected to a higher voltage but slower = bipolar transistor.
Saurabh.30
Joined Apr 27, 2021
6
cannot find anything for "75AC125" can you please elaborate
Joined Dec 31, 1969
To select a driver, you need to know,
Just what are you aiming to drive , at what sort of edge speed ?
One size does NOT fit all.
