Hello Let's say you have a current source that keeps on increasing in current and voltage and you have two outputs from that source one with a resistor and one leading to ground . Will the resistor limit the amount of current/voltage coming out of that output and cause the rest of the current/voltage go to ground without blowing the resistor or will equal amounts of current go to the resistor and ground eventually, because the current/voltage is increasing, blow up the resistor anyways. Thanks.
