I was curious what would happen hypothetically if in a DC circuit consisting of only a push button switch and an inductor ( 10 ohms resistance) No capacitors, resistors or diodes.
What would happen to the current and voltage if you were able to push the button with your finger 5000 times per second?
If current increases with voltage and voltage is increased by the inductor wouldn't you technically be able to dial up any amount of voltage and current you desired?
