Increase current output of a voltage regulator
dl324
Joined Mar 30, 2015
18,462
When I drop the airstone into water the current goes up to 350mA but the motor stalls. I get the same response when the power source is batteries but the motor doesn't stall
Measure the voltage on the input and output of the LM317 when you're trying to draw 350mA.
What is the nature of the heatsink? The regulator will be dissipating more than 3W and it will go into thermal protection if the heatsink isn't adequate.
I didn't bother looking for specs on your 12V power supply. Can you post the specs? Particularly, current rating and whether DC output is regulated.
