Can LD1084V be used in parallel to increase the current output?
gvi70000
Joined Oct 4, 2009
38
ericgibbs
Joined Jan 29, 2010
21,644
hi gvi,
Which part of the application sheet circuit for the LD1084 you cannot figure out.?
Post your proposed circuit, with component values and voltages, we can then check.
E
ericgibbs
Joined Jan 29, 2010
21,644
hi gvi,
As a demo simulation, this uses two LM317, assumed current limit per LM317 of 1.5Amp, set for +5Vout.
It appears to track OK for the loading.
E
ericgibbs
Joined Jan 29, 2010
21,644
hi gvi,
This is your ciruit in simulation.
You can see the value of Rslv is super sensitive to ensure tracking.
I will keep trying ideas.
E
mblassd
Joined Jun 8, 2022
The answer is simply yes! As paralleling distributes the heat and load in most ICs, however, frequent paralleling isn’t recommended.
