Hello everyone,
I am going to use the pickit-3 for programming and debugging purposes.
I have a doubt regarding the MCLR pin connection and operation
Currently i have MCLR pin and VDD pin tied to the same supply rail directly.
Will this be a problem?
I am asking because as per the PICkit3 manual there is a 50K ohm resistor in between MCLR pin and VDD.
Also will the pickit 3 drive the MCLR pin when connected or is it the other way around?
Here are the 2 circuits :
And my target circuit configuration as per datasheet
R = 10K,R1 = 470 ohm
Currently i am taking MCLR pin connection to PIckit3 header(pin 1) after R1 resistor.
And i am taking VDD(pin2) from "R"
