- Joined Jan 23, 2018
- 28,403
OK, folks. I admit to not considering that the TS only had a limited parts selection. It was an option I suggested to reduce the cost, because transistors with a slightly higher voltage rating are often cheaper than those with a considerably higher current rating. So the four bulbs could also be operated in parallel, and the switching transistors will need higher current ratings. Not a huge problem.
