Inaccurate voltages read by arduino when charger plugged in
bkhan10000
Joined Jan 18, 2017
31
Hello fellow electronics enthusiasts,
I am trying to use an arduino to monitor voltages of a 6 cell lithium ion battery in series as it charges. My set up is simple. Each terminal of each cell is connected to an analog input pic via a resistor voltage divider. Here's the thing, when the charger is not connected, the voltages are read fine by the arduino as confirmed by a dmm. When the charger I connected the voltage measurements become inaccurate by about a half volt. The dmm reads about 3.9 volts across each cell whereas the arduino reads something like 4.5 volts across each cell. The way I connect the charger is that the negative terminal connects to the battery and the micro controller ground and power goes to positive terminal of the battery. What could be going wrong here? All help and information is appreciated!
Regards,
Khan
LesJones
Joined Jan 8, 2017
4,544
Check that the ADC reference voltage does not change when the charger is connected. To get further help you need to post a FULL schematic .
Les.
AlbertHall
Joined Jun 4, 2014
12,663
You should have the charger connected to negative of the battery and a separate wire from the negative of the battery to the arduino ground. This ensures that the arduino is not measuring voltage drop across the charger wire.
There may also be a problem if the the charger output and the arduino power supply are both grounded - it's OK if only only one or neither are grounded.
bkhan10000
Joined Jan 18, 2017
31
Les.
Hello Les,
Thanks for the input
I'm using the internal reference and you're right. The value of the reference does change a bit, but not enough to explain the half volt inaccuracies. Any other suggestions?
This maybe true. I'll try it and get back to you.
