recklessrog
- Joined May 23, 2013
- 985
Could you define exactly what you mean by "better" please? what parameters are Improved over the original? thanks.
I was asking be80be to quantify what he meant by the statement "output is better." How is it "better" what does "better" mean???RE:""Could you define exactly what you mean by "better" please?""
As the Multivibrator concept works well practically on EVERY kind of components, from 1950 elaborated russian MP14 until high-power 2N3055 (bit adjusting the resistor values), from russian kt315, 361, 3107, 3102 to beta factor variable 2n2222 or 300 MHz able BC547, low noise BC549, and this list may include even thousands of any other immagineable bjt~s or even jFET~s/MOSfets. More, this circuit works well even at so high as 100 MHz with proper F(T) transistor or more. It works well even at minutes long pulses, with proper jfet and electrolytes, it works well even at 1200 Volt Vcc if harsh need and is capable to work even from 1 Volt Vcc if germanium. Actually much more productive ought be questions - do there at all exist a transistor with which this circuit is unable to work.
Yes it should work perfectly . I think any NPN transistor which is having a 'beta' more than say 30 should work without any problems . You can use 2N2222, 2N3904 etc . Judging by the RC time constant of your circuit I presume it is a low frequency multivibrator only and it should readily work with any of the above NPN transistors.![]()
I am currently trying to build this oscillator circuit for a project at school, but we don't have any BC547 transistors available. We do however have many 2n2222a transistors. Can I switch the transistors or modify the 2n2222a's to make the circuit work?
That's a good point; I can't think of any.Actually much more productive ought be questions - do there at all exist a transistor with which this circuit is unable to work.
