In-amp general opamp unavailable on LT Spice
fbp
Joined Aug 9, 2023
30
I am trying to find a generalized Instrumentation amplifier component on LT Spice, since I want to import a new In-amp library.
But I am unable to find it.
Please guide me.
Papabravo
Joined Feb 24, 2006
22,115
AFAIK there isn't one as I understand the meaning of the term. You can easily construct one from generic opamps with or without power supply connections.
38,909
So if I understand correctly, you want to import a new In-amp model.
For that I just modify a symbol already in LTspice that has the same pinout as the new model.
So, for example, if your In-amp has the typical 8 pins (as below), then I edit its symbol to reference the new model and pinout, change the symbol name, and save the symbol with the new In-amp name.
Also put the new model file into the sub folder in your LTspice file location.
Then when you reboot LTspice, it should show the new device.
Papabravo
Joined Feb 24, 2006
22,115
I thought the TS was asking for a generalized INA model, with explicit parameters as attributes, not an additional model of an existing part. My mistake if that was his intention.
