In a bind and the clock is ticking (cap help)
joekr11
Joined Jul 3, 2010
4
Hi guys,
I donate most of my free time repairing music instruments for a rock n roll high school for kids in AZ. I recently took on a bass amp repair that is on a tight deadline and I'm kind of stuck. I have a cap that burned off on the tube side of the preamp. Easy enough repair, but turns out the cap has a number that I haven't seen before and I can't find anything on line about it. The number is 474J 100N. The 474J is no problem I knnow what that is. Its the 100N that has me confused. Any insight would really---REALLY be appreciated. I gotta have this thing on stage on the Forth! Thanks!
joekr11
Joined Jul 3, 2010
4
Wow! Thanks for the fast replys! I'm taking a picture right now. in the mean time the Make/Model is Hartke 2115 combo (2000 series head and 1 15" speaker in same cabinet.) I've emailed and called Samson/Hartke and they won't give me the time of day.
SgtWookie
Joined Jul 17, 2007
22,230
Actually, that looks rather like some old silver mica caps that I have. However, the ceramic should do just fine; this isn't an RF application.
bertus
Joined Apr 5, 2008
22,943
Afther having a second look at it, SgtWookie is right.
It is a silver mica capacitor.
For an audio application the ceramic I showed you will be OK.
eblc1388
Joined Nov 28, 2008
1,542
I would say it is NOT a silvered mica capacitor but a Mylar one.
A silvered mica capacitor of this capacitance will be very large in size. Also the 100V rating does not seen common with SM capacitors. Why use a silvered mica capacitor in an preamp when a Mylar one can do, with one tenth of the cost?
Usually Mylar capacitor are green but i have also seen brown and occasionally the color shown in the photo posted above.
