Important Circuits(Building Block Circuits)
jacaylor
Joined Nov 2, 2020
6
Hi all,
So I am trying to create hierarchy chart of electronics, and in turn a compilation of important middle tier circuits that are the building blocks of larger circuitry. Say for instance like a basic eq circuit, basic compression circuit, but also like subdividing that, so then basic clipping circuit, basic volume control. If you can't tell already, its cause I am rather interested in guitar pedals. Anything anyone could add to this would be awesome.
blink13
Joined May 26, 2022
27
Voltage and current dividers
RC circuit
Filter circuits
Maybe voltage and current dividers at the very base because IIRC I have to run my signals with them when trying to bias them, plus they are about 90%+ in circuits I make
28,322
Two Things: First, the "schematic for free" site has a whole lot of music electronic circuits available for download.
Second, along with the circuit you save, also include the power supply voltage and interface impedance values. That will allow linking them with less experimenting required.
LowQCab
Joined Nov 6, 2012
5,102
http://www.muzique.com
It seems that the ESP site no longer exists ....... maybe the Way-Back-Machine ???
My Folders, even in Zipped format, are too big for the Forum file-size limitation.
I'll give You a hint ......... EQ, EQ, EQ, EQ, EQ, everything.
