impedance vs frequency
MrAl
Joined Jun 17, 2014
13,707
Well to start it depends what impedance you want to find, input, output, or other.
The methods vary slightly.
Do you know how to analyze AC circuits using a frequency like w=2*pi*f ?
If so that makes it easier. If not, we have to do some work.
Bordodynov
Joined May 20, 2015
3,431
Do analyze AC
Parallel input pins connect source current. For example:
Iin pin1 pin2 dc 0 ac 1 .
The voltage on pins will be equal to the input impedance.
Is it Similarly defined output impedance.
I use this method for a long time.
Bordodynov
Joined May 20, 2015
3,431
in2 is just a name. Actually I am not quite right. On the input impedance affects more load. Unfortunately I do not know what the source and the load. It is more correct to connect the first circuit on the output load. The second to the input must be connected (in parallel) of the generator impedance. If this is done, then all will be correct.
anhnha
Joined Apr 19, 2012
904
Thanks. So for the output impedance, you are leaving the input float. I think it will be more exact if we assume the input voltage source is ideal and then short the input voltage for output impedance measurement.
