Why is the impedance vs. frequency graph in the datasheet does not correspond to the inductance value of the inductor
ek98
Joined Apr 23, 2024
In the datasheet of the 1.5 uH inductor "7440450015" from Würth Elektronik there is the typical impedance characteristics curve which I also attach here. However the impedance values well below the self-resonance frequency does not correspond to the real inductance of the inductor.
For example at 1 MHz the impedance is 5 Ohm. So from L = X/(2*pi*f) we have 0.79 uH, much different than what it should have been. What am I doing wrong? The curve actually considers the magnitude of Z and not imaginary part of it, but at 1 MHz the real part of it should be negligible, so shouldn't my calculation above be correct?
panic mode
Joined Oct 10, 2011
4,947
yup... seems way off... at 1MHz R=0.09Ohm, Xl=9.4 Ohm so to get impedance Z=5 Ohm it would also need to have Xc=4.4 ohm which would be parasitic capacitance of some 36nF. but that is if one considers sine wave. pretty sure these inductors are meant for SMPS so waveforms and results could be different
27,366
Are either of the graphs plotted from accurately measured results? Using accurate measuring packages? Or just plotted from a few calculated values? Every inductor has some amount of resistance and some amount of capacitance between turns. And other variables unknown to most of us.
ek98
Joined Apr 23, 2024
As WBahn said, it seems to be an error in the datasheet, because when simulating the Spice model of the component created, again, by Würth Elektronik with all its parasitic capacitance and resistances specified, the impedance-frequency behavior that I am getting is much closer to what I was expecting.
