There is an obvious way to find out.Does short circuit damage to IGBTs typically happen because they switch currents much higher than the DC curve in the SOA? Would the IGBT be damaged if short circuit power is within its safe operating area?
It's kind of like popcorn. It doesn't pop when you first turn on the microwave. It has to heat up.Does short circuit damage to IGBTs typically happen because they switch currents much higher than the DC curve in the SOA? Would the IGBT be damaged if short circuit power is within its safe operating area?
by Aaron Carman
by Aaron Carman
by Jake Hertz
by Aaron Carman
