geekoftheweek
- Joined Oct 6, 2013
- 1,223
I have a thought in the event this does turn out to be an over current situation. Inevitably either 2 days from now or 10 years down the road it will happen again. How about setting up a comparator to either short your input of your gate driver to ground (with the appropriate components), or use the comparator of the PIC to shut off the gate driver in software? I started playing with an 18f45q10 that has some configurable logic in it that isn't dependent on the program other than to set it up that would actually work out nice in this case.
I kind of forgot to mention I was referring to comparing the output of your ACS722 to a whatever voltage works out for say 10 amps or whatever.
