If you want you can remove the opto from the circuit and replace it with a BJT transistor. The opto is just for safety, nothing more.its putting out -15.10 volts out of the opto i have to get more optos before i can go any further
There are no npn and npn MOS.i have some pnp and npn mosfets
Can you explain better what happened and provide a diagram. Also, it would be better if you use commas and dots sometime!i tried a mosfet before the igbt i didnt do what i needed it to the two signals entrained and it turned into a half wave dc with square waves imposed on it when i was trying to cut the half wave into 4 half on half of section but it probably my doing and not the mosfets fault since i dont know what im doing
