IF statement on LTspice
Firenze02
Joined Sep 1, 2018
47
I would like to create a variable resistor as following:
R2=1 if i(R2)<1
R2=2 if 1<i(R2)<10
R2=3 if i(R2)>10
I know that the sintax is:
R=if(condition,valueiftrue,valueiffalse)
What about if I have three intervals?
The .asc file and the IF statement law is also shown in the attached files.
Which is the correct sintax to do that?
Thank you.
Firenze02
Joined Sep 1, 2018
47
HI
The statements are incomplete.
Write them in "if then else" pseudo code so we understand what you want.
eT
Dear eetech,
I would like to "translate" in LTspice the following code:
if i(R2)<1 {
R2=1
if i(R2)>=1 && I(R2)<=10 {
R2=2
else{
R2=3
eetech00
Joined Jun 8, 2013
4,724
See below.
In the .func statement, the "if" statement has to resolve to a number. I've added 0.5 at the end.
In the "Limit" statement, I've added arbitrary Min and Max values, 0.1,12, respectively. A discontinuity will occur if not used because at the start of the simulation R equals nothing (NaN). This will produce a "time step too small" error. The "Limit" statement will keep R2 equal to some value between 0.1 and 12.
eT
Firenze02
Joined Sep 1, 2018
47
See below.
eT
Thank you eetech,
Finally I was able to simulate the circuit that I wanted, but unfortunately it doesn't work.
It gives me the following message:
Analysis: Time step too small, trouble with node v4.
Please find attached the .asc file.
Can you help me?
Thank you.
