I have a Sonos Play:3, which is past its warranty. I dismantled it to find it has the well documented fault with a blown capacitor. However, there is also damage to one of the surface mount diodes. I have sourced some new capacitors to replace those, however I am not sure what spec this diode is, and wondered whether any of you have had the same issue and if any solution was found? It appears to be D307, and has a code of AN 97 printed on it. As far as I can see, I will have to bridge the track to wherever the diode's anode was connected.
Any advice would be greatly appreciated, as I cannot find a schematic or circuit diagram anywhere, and the board is quite badly charred!!
