Identifying an SMD Diode
Anna Swinemar
Joined Oct 31, 2017
31
Can anyone help identify this diode? See attached photo.
I tried looking through the SMD code book with no luck.
Looks to be a Motorola?
The dimensions are Length= 4.3mm Width= 3.4mm
Anna Swinemar
Joined Oct 31, 2017
31
Thanks for your reply!!
Can't seem to find in the SMB package style.
Something to note. The diode is shorted across pins 1 and 2 (input and ground) of a 7805 voltage regulator. Which the input of the VR has a max voltage rating of 18V. I originally thought the VR was bad but after removing from the circuit, it tested good and the short remained on the board.
28,626
Interesting problem, a "short" on the input side to a regulator. It might even be that diode, put in as protection.So tracing the up-stream circuit to see what else could have failed and be the short.
