Identify old IC
skusku
Joined Aug 9, 2009
80
Hi everyone
I have a machine which has some blown and rusted IC's. Problem is they are very old IC's.
The IC's are labeled D08 E102. Used in a plastic moulding injection machine.
Could anyone please help identify the type of IC and possibly a replacement IC that I can use?
alfacliff
Joined Dec 13, 2013
2,458
it might not apply to yours, but I found some chips marked with the origional part number on the bottom, even when they had a propiat=ery number on top. might try locating pins connected to ground + supply and such, and what supply voltage they are connected to, most chips of that package were +5 volt only except for some that were driver chips. analog have different supply voltages.
Hypatia's Protege
Joined Mar 1, 2015
3,228
The logo tells me the ICs are a product of Matsushita (i.e. Panasonic q.v.) --- Panasonic should be able to advise you as to the 'owner' of the Spec. (e.g. Panasonic themselves or the manufacturer of the machine, etc...[if manufactured under 3'rd party contract])
In my experience manufacturers/'rights-holders' are very helpful with such inquires! :)
Best regards HP
RichardO
Joined May 4, 2013
2,270
The crud in the picture looks like it is flux left over from a previous repair. I suggest that you use some isopropyl alcohol to clean the board and then do a careful visual inspection for broken traces or lifted component pads. Do the cleaning and inspection on both sides of the PCB.
Another thing to check is the gray cable near the bottom of the picture. These cables quite often use solid wires and even a couple of flexes at the circuit board can break some of the wires.
Reloadron
Joined Jan 15, 2015
7,890
My guess, based on board position is possibly resistor networks having 8 EA of 1 K resistors used for pull up or pull down. That is purely a guess. If the grey ribbon cable can be disconnected from where it goes and left floating try measuring accross the chip(s). Pin 1 to 16, pin 2 to 15 and down the line. 1K seems strange for a pull up or pull down but I figure resistor networks if I had to take a wild guess. As suggested, clean the board up.
Ron
atferrari
Joined Jan 6, 2004
5,012
Matsushita (Panasonic), or it is the other way round? does not produce them anymore. It is all SMD nowadays since long time.
If you finally desolder them, measure resistance (between opposite / contiguous pins).
What a mess there...!
Hypatia's Protege
Joined Mar 1, 2015
3,228
Well indeed not!:D -- however they will have data, and, perhaps, 'leads' on stockpiled NOS devices --- FWIW I have had very good experience in this regard... But then, perhaps, it was merely down to my winning smile!;)
Best regards
HP
skusku
Joined Aug 9, 2009
80
Thank you so far guys. I have emailed panasonic Industrial support. I will see if they come back for help. I cleaned everything with alcohol and replaced resistors and one zener so far.
Scotophor
Joined Oct 8, 2014
8
Even if Matsushita/Panasonic are of no help, if you can confirm that they are resistor arrays, that is a fairly common part which you can get from many sources. However, they're also unlikely to have failed in the first place.
The "crud" in the photo looks to me more like corrosion bloom from exposure to moisture. This stuff can retain moisture and be conductive, so definitely clean it off before attempting to power the circuit or continue diagnosis.
Automatyka
Joined Sep 6, 2020
1
Hi everyone
Hello, did you found a replacement for this old IC? I have the same problem and I need to replace the same D08 E108. Can you please give me information about it would be so much help.
Reloadron
Joined Jan 15, 2015
7,890
You may want to get a good acid brush or similar brush with stiff bristles and trim it down. Use the stiff brush to scrub down the corrosion which is apparent. Looking at the designations on the board I still would consider what I mentioned in post #5.
Ron
