Identify current capabilities of schematic
ericgibbs
Joined Jan 29, 2010
21,552
hi A,
If you know the current rating of the load that you are trying to filter, choose a wire gauge current rating about 25% higher.
Depending on the space available chose the biggest choke core with the most windings.
A bit of trial and error will be required as you have not specified the load or voltage source etc ..
E
