Ideas for laptop power supply
SuperMoist
Joined Nov 28, 2010
3
hey everyone, I need to fashion my own power supply for my laptop. It requires 15 volts DC at 5.0 amps. I have the old charger but it shorted out and blew what I believe to be 3 resistors off of the board and I can't figure out what resistance they were or even if they were resistors. I'm guessing they were because on the board they were labeled R04, R05, R06. I don't have the money to buy a new charger but I need my laptop asap. I have plenty of electronics and various AC to DC converters to take things off of or reduce, raise or combine voltages. I have diodes, capacitors, resistors galore. Anyone have any ideas where i should start? Old desktop power supply? I'm thinking of redesigning the supply from everything on it only taking the resistors off of something else and making it all onto a new board.
Wendy
Joined Mar 24, 2008
23,807
I'm working on a similar project for an Asus netbook. Mine is 9.5VDC at 2.9A.
I see plenty of laptop power supplies available online, I suspect that is your best option.
SuperMoist
Joined Nov 28, 2010
3
like i said... i currently don't have the money to purchase a new charger and i need the laptop at the latest by tomorrow for work.
SuperMoist
Joined Nov 28, 2010
3
yeah my real smart roommate caused them to. The rest of the charger seems fine. He was messing around with the LED on it and left some extra solder on it causing a short but I checked everything else with my ohm meter according to the ratings and like I said... everything seems ok. I don't mind experimenting with it I just need some ideas... if not to fix it then just to fashion my own. Even hardwiring to the battery terminals. I need this laptop running by tomorrow at the latest.
iONic
Joined Nov 16, 2007
1,662
It's good that there is a explainable reason for the damage, but know what the parts are and their values are not a task that will happen overnight. Building a safe replacement is also not something that would likely happen overnight. You best solution would be to borrow an adapter from someone with compatable voltage and a current rating of at lease 4A. You may also need to insure that the output connector is the same and that you match the polarity of the connector(center positive or center negative).
Easier still would be to borrow the money and buy a replacement! It would be tough to locate a transformer or wall wart that will produce 4 or more Amps after regulating.
iONic
windoze killa
Joined Feb 23, 2006
605
You may also have problems if the laptop is one that checks the power supply for its ID tag. Some power supplies have a small EEprom with a ID on it. If the laptop doesn't detect the right ID it won't power on. If this is the case a direct replacement will be required if you can't fix it.
iONic
Joined Nov 16, 2007
1,662
Interesting feature...almost an invasion of privacy of sorts...it keep the replacement dollars in Dell's pocket.
tom66
Joined May 9, 2009
2,595
Yes, Dells have that ID tag system.
It's completely stupid as well. That long lead going to the laptop and connected to the EEPROM/whatever - guess what that's called? An antenna. This means it is very susceptible to static damage. I've had two die on me so far, replaced by Dell under warranty. Somehow I think it must cost them more to replace them than the revenue lost to competitor power supplies. The laptop will run off the power supply if it doesn't authenticate, but it won't charge (deliberately disabled.)
To the OP, designing a switch mode power supply is very difficult. Especially one operated off the mains. There are many safety regulations. You can make a career out of it. To that end I recommend you buy one of these: http://www.maplin.co.uk/Module.aspx?ModuleNo=225874. I don't know where you are, but look for something similar. Then send the bill to your friend.
SgtWookie
Joined Jul 17, 2007
22,230
Hey Bill,
Those SMT UC2842 switching regulators that I sent to you would work fine, with proper aux components. One of the "line item 44" toroids (see the packing list) would be good for a basis of winding a transformer. If you need details on xformer winding with those toroids, PM me. I thought I'd sent you some IRF730's, but I see now that I didn't - they'll be in the next box if you'd like.
None of this will be fast enough for our OP.
I would insist that he replace it immediately, as you need your laptop, and the power supply was working just fine until he messed with it.
tom66
Joined May 9, 2009
2,595
@tom66
u said it won't charge....how is tht possible?
Does HP use ID tags too?
It won't charge the battery but it will let the laptop run off the AC adapter.
I don't know about HP. I make a habit of avoiding HP computers, I've had a bad experience with them.
thatoneguy
Joined Feb 19, 2009
6,359
He broke it, he should replace it. Unless you gave him permission to take apart a perfectly good/needed power supply.
You can get older notebook power supplies at the no-name-brand PC Stores that pop up in every town, one of them should be what you need. The one here even sells new Branded ones from various manufacturers, as well as spare batteries for a ton of notebook models.
