I was reading a data sheet on some IC that has a Vcc pin, and an Enable pin (among others). The data sheet said that the input supply voltage should be applied prior to the application of the enable signal high. And then the enable signal must be set to low before removing the supply voltage.
Is there a simple way to do this?
Thanks!
Thanks!
