IC Timer Expert Help
Alec_t
Joined Sep 17, 2013
15,118
I haven't studied the datasheet in depth, but would disabling any of those pins actually cause the IC to shut off? That's the opposite of what is wanted.
Edit: Ok, after checking the sheet further it seems holding pin 1 high and pins 2,7,14 low will cause the output (pin 13) to stay high (=on).
dociledragons
Joined Oct 6, 2013
10
OK thanks for the reply everybody.
Sadly, I shorted out the circuit. Ops... So, now I'm in need of curcuit that that can power the heating element safely.. Would it be as easy as a Potentiometer, a couple resistors, diode??? Except I have three wires coming out the heating pad. I can assume the third one is the thermometer.
Any help would be appreciate. I no I could purchase a light dimmer but those are 10 plus bucks. If I were to do that I would just purchase another heating pad.
Edit: I just need it on a "High" setting.
Alec_t
Joined Sep 17, 2013
15,118
It might not be safe to ignore the thermometer wire. The pad could overheat if powered uncontrolled. Depends on the design/spec (unknown).
